I think my math is correct on this, but if someone finds a mistake, please point it out. You would need to do as follows:
You’re using a ball smaller than the gage dimensions call for, based on the 30 degree angle and the 0.705” tangent points, the correct ball would be 1.41”. Since your ball is 1”, you need to compensate for that. This first picture finds the new tangent distance, which is smaller since your 1” ball is smaller than the design size.
Next, you need to find the change in the horizontal dimension needed, since your tangent points are closer together, your horizontal dimension will be shorter.
Now, to find your AB dimension, you need to add the radius, plus the horizontal dimension from the ball center to the tangent point, plus the original gage dimension, minus the change in length. I get an AB dimension of 1.688.
An important point, you need to make sure your new tangent points with the smaller ball is larger than your bore. I get a tangent distance of 0.5” with the 1” ball, so if your bore is that size or larger, these formulas will not work. You can do the calculations for any size ball but replacing the diameter of the ball in the formulas and going through the same steps.
