- Nov 14, 2016
- 3,018
Thanks, Aaron.
I had considered most of the Grizzly machines and decided that they all were either too big, or had too many compromises I’d regret later. I took another look at the ones you suggested and came to the same conclusion again. That G0822 comes pretty darn close, but I really think the work envelope would prove to be too small. If you price it in terms of $/unit of work volume it’s actually a fairly pricey machine. That tall base unit just eats up too much space, it’s a shame. I do admire the space-saving configuration of the drivetrain, with the inverted motor hanging out in the back. In fact, I have toyed with the idea of rebuilding the PM835 into a similar configuration. The motor couldn’t go all the way at the back, the ram is too deep. But it could be hung to the left side of the head, just aft of the head bolts, which would allow access to all controls. Would have to reverse the motor rotation. Hmm, maybe that idea is back in contention... Although I’d be burning the warranty, I assume.
I’m definitely on board with multiple machines! One of my first complex projects, which is currently simmering on the back burner, will be a clockmaker’s lathe.
It's not easy when you have limited space, everything seems to turn into a compromise.
Last year I was looking at PMs bench mills up to the PM30 which was the absolute biggest I could fit without losing its full capacity, and at 6'4" fully extended that was pushing it, at 6' 10" the PM-932 was just too tall for me. I looked at a Millrite which looks like a small Bridgeport but even it would have been right up against the ceiling and tucked in between the floor joists greatly interfering with access to the head, drawbar, and ability to swing / tilt the head. These Grizzly mills seemed to fit me quite well, but the Clausing found me before I made any decisions (sometimes indecision is a good thing).
I thought the Grizzly G-731 compared quite well to the PM-30 and the PM-932 is just a pinch larger, but you are looking at the full frills version, and oddly Grizzly doesn't offer anything like that on the 8x30 mills only on smaller the 6x26 0822 which then does give up a lot of working space, particularly vertical travel.
When you start talking about fitting the head between the rafters, it seems like you really begin to limit the capabilities, that can and likely will interfere on your ability to tilt or swing the head which you do mention on the 835. It really is too bad that nobody currently seems to be offering a higher end "mini Bridgeport", it seems like there were plenty of options in the 70s and 80s.
It was suggested to me that I lower the floor...
