- Jan 22, 2011
- 8,031
Take a 3/8" single end endmill and grind some top relief on it and drill amd ream a hole at the correct angle in a piece of steel that will fit your holder and with the end mill "on end" it will cut close enough to the right radius. You can use set screws to hold the end mill in place or silver solder it;
