Help Identify This Drilling/Milling Machine
I see that at the column back, there is a disconnect box. Check the box to verify if it also do have fuses. If so, they should be match to the motor capacity, and you will not depend on the panel breaker for the protection of your equipment.
Happy milling!
Good eyes!! A properly fused disconnect is the right way to go.
I have a Complex MD-30 which is really close: Here is a scan of the manual .
  • complex_MD30.pdf
