I'm really hoping someone can help me here because I'm completely lost. I was trying to turn some 3" O.D. cold rolled tonight and noticed my lathe wouldnt even take a .010 pass it just chattered really really bad. I did all the common sense stuff like double check tool height etc etc, then noticed I could move my cross slide in and out I'd say probably .010-.015" by hand. I'm assuming this is where the chatter problems are coming from. So I went over it all and adjusted the gibs and backlash and everything, still no difference. Took the compound off and noticed that I couldn't move the cross slide anymore. So I put the compound back on and tightened it and it was back. Then I just loosened the compound and the movement was gone again. Its something happenning when the compound is tightened but I can't figure it out. Sorry for writing a book and thank you all in advance for any input.
