- Nov 21, 2012
- 793
I know there have been posts about the pro's and con's of belt grinders but I'll give you my experience.
I have 2 bench grinders (both industrial) and an industrial belt grinder. I rarely use the bench grinders anymore. Even with the bump on the belt, the belt grinder manages heat better, is more flexible and is safer. I also use it for flattening surfaces on the plenum to spare my end mills or to save installing the horizontal milling head. It is better for sharpening mower blades and axes and the belt change to courser or finer belts is literally done in the flip of a lever. You will pay more for the belt grinder and it takes up a bit more room but I think it is a better all-round machine. Having used bench grinders for years, I have also noticed a sharp decline in the availability of decent grinding wheels, while good quality grinding belts are still readily available.
Paul.
Paul.
