- Feb 15, 2015
- 65
Well, machinists are a pretty opinionated bunch, and you definitely have a lot more machining knowledge and experience than me (your post history is great),
but "this Hall fellow" is a pretty well respected author of a very large number of books and articles on model engineering and machining in general. I think he is or used to be the editor of the Model Engineers Workshop magazine in the U.K. To me, he's right up there with George H. Thomas.
What clamping method do you recommend for faceplate work? Mr. Hall's clamping system seems reasonably compact to to me. I'd be hard pressed to come up with anything more compact other than super-glue on freshly faced aluminum, but I'm still learning. (I use-super glue all the time for small one-off parts and light cuts, but its kind of a pain to clean up, especially with multiple setups.)
Seriously (no disrespect at all): if you have a better suggestion for faceplate clamping I'd also like to see it.
With respect to the original question, I'd recommend a "one part a time, one operation at a time" approach for a project like this (or almost any project). Definitely do not bore a deep hole through a long piece of stock as the first step before cutting pieces to length! Drill bits tend to wander, and deep boring jobs are a PITA anyway as you have to keep retracting the drill to extract chips. You can sometimes get away with drilling all the way through and then parting off multiple parts, but it's also easy to get into trouble that way.
For example, I'd machine the packing pieces as follows:
This completes the first operation, creating center-bored parts of the correct length. The second operation would be on the mill to bore the non-centered M6 hole. I'd do it as follows:
- Chuck up a length of material in a three jaw chuck, with about 1/8" more than dimension A extending from the jaws.
- Face.
- Center drill, then M6 drill to a depth slightly deeper than dimension A.
- Chamfer the bored hole slightly with a 90º countersink (to remove any burr).
- Break the edges with a file.
- Part off at dimension A. (Remember to break the inside edge with a file before parting all the way through.)
- Extend more material, then repeat steps 2-8 for the number of parts desired. (Parts will already be spotted, though, so no need to center drill)
- Flip and re-chuck each part to chamfer the hole on the other end with the countersink.
The third operation is also on the mill to create the step. I'd create a super simple fixture out of aluminum to orient each part: just drill two M6 holes the correct distance apart in a piece of aluminum, then use pin gauges (or drill bits) slightly smaller than holes to align the parts before clamping them in the vise. After milling the step in each part, I'd do the final countersink chamfering and de-burring of the milled step edges by hand.
- Insert the part in the vice. Use a v-block, parallels, and vice stop to repeatably hold each part in the same location.
- Position the table to drill the offset hole.
- Center drill, then M6 drill through the part.
- Chamfer the drilled hole with a countersink.
- Repeat steps 3 & 4 for each part.
There are almost certainly more and better ways to do it, but that's how I'd approach the job. The idea is to make set-up changes between operations, as much as possible, rather than within an operation.
Hope this helps.
Rex
Thanks Rex, that is exactly the type of input I was looking for. I took a class at our local community college but they didn't go into work holding or sequencing in much detail. The program was geared more to getting into CNC than traditional machining.
I like your idea of the alignment fixture. I was trying to figure out a way to do keep alignment without having to change from a drill to a mill for every piece. I can turn down a couple of pins easy enough.
I'm still tempted to drill (not bore) the center hole through and part off using a horizontal band saw rather than parting off each piece. My 7x12 lathe does not like to part very well compared to the much larger lathes I used at the college. Could be the type of QCTP I have and the resulting overhang - the tool gets cantilevered well to the left of the cross slide. It is the Harbor Freight QCTP and I can see the tool post lean because of things flexing when I cut off. I guess I could try using the original tool post for cutoff operations as an alternative.
I've cut the round stock down to 4" lengths for groups of parts. How bad do drills wander over 4" if you use a center drill with a reasonably well aligned tailpost? These clamps do not have critical tolerances.
