- Feb 15, 2015
- 65
I need some advice on setup and sequencing. I'm going to make Harold Hall's faceplate and angle plate clamps and would like some input on the best way to make the packing pieces and bushings. The rectangular stock items are pretty straight forward. Since there are lots of pieces - I plan on making four of each size and there are seven sizes plus washers - I would like to minimize setup and operations. For those who are not familiar with these, information including drawings can be found on Harold's site here: http://www.homews.co.uk/page39.html
The following is my best guess for sequence:
1. Drill the holes in the stock before cutting to length.
2. Cut the stock in the horizontal bandsaw.
3. Make a pot chuck, sized for the smallest piece, to hold the pieces.
4. Face one end, turn around and face to length. Chamfer edges.
5. Mill the step in the packing pieces.
6. Counter bore the longer packing pieces so there is less tapping to do.
7. Tap the packing pieces.
The holes will be different sizes for the packing pieces and the bushings. Should I drill the holes on the lathe or use the mill? I have two 12" long pieces of 1" diameter 12L14 if that makes any difference. I was thinking it would be easier on the lathe. I have a four-jaw so it wouldn't be too difficult to offset but I would have to cut the stock down since there would be too much overhang and the stock won't fit in my mini-lathe spindle. If I have to cut the stock down, it might be just as easy to drill on the mill.
Will a pot chuck size for 2mm be adequate to hold the longer pieces? How much of an overhang can I get by with for about 1.5mm grip? The alternative is to make some kind of spider for the longer pieces and grip them in the chuck.
Thanks guys.
Thanks guys.
