- Jan 28, 2011
- 3,486
Easier to get second 110 circuit from the other leg and then use a VFD. With the 2 110s giving the 220, you just need a VFD to run the motor.
A transformer like this - http://www.voltage-converter-transformers.com/step-up-down-transformer.html
What is the amp draw of the motor, could maybe give you what you need as a 3ph 220 motor draws less per leg than a single phase motor. One of the larger ones may work, but it depends on the wiring to your area. Is it limited to 14 gage 15 amp or is it better 12 gage 20 amps.
It is all about the amps(watts) available.
