- Nov 27, 2012
- 7,855
I've probably said this too many times but I have little space. No dedicated space for lots of things so I put them away when not in use. Built a stand for the belt sander using a bench grinder stand & mobile base. For the past year it's been sitting on a little table (what the drill press is sitting on in the pics). Now I just need to figure out where it's parking space is going to be.
Came with a hook for the power cord which was unexpected. Gave me an idea to maybe add more hooks for my extra belts. Not sure yet.
WIP pics:
See, no room! Had to roll the bandsaw outside. You'd laugh if you saw how I got the 10ft square tubing home.
This plate was too large to cut in my bandsaw in the horizontal postion unless I made multiple smaller cuts. Didn't want to waste material like that so I cut with the angle grinder then made the final clean up cuts with the bandsaw.
Absolute widest my bandsaw can fit between the jaws. Fixed jaw moved to the outer mounting position.
Cookie cutters are great for marking radii that aren't critical. My radius gage set only goes up to 1/2". Not my idea but I thought it was a great idea.
Had to notch the mounting plate.
Delrin stand offs.
Needed to remove the disc side to access one of the mounting holes. Sure I could have just put the nuts on top instead of on the bottom but it looks much cleaner this way.
Thanks for looking!
WIP pics:
Delrin stand offs.
Thanks for looking!
