- Feb 1, 2015
- 9,605
If by variable speed lathe, you mean one powered by a DC motor, there is a possible cause. DC motor require rectification of of the ac supply followed by a filter capacitor. On initial energization, the circuit is subject to a large inrush current due to charging the capacitor.Me and some others were having random non-GFI breakers trip instantly on startup on a variable speed lathe before the motor would actually be turned on. The only thing that stopped it for me was a 30A breaker.
This can be dealt with in a number of ways. The simplest is to add a small resistance to the input to limit the surge current. This however reduces the efficiency of the supply which can be objectionable for high current devices like a lathe motor.
Another way is to use a negative resistance device, aka varistor or inrush current limiter. It has a fairly high resistance when cold, limiting the inrush current but as it heats up, the resistance drops significantly. This method is often used for switching power supplies. One that I used was this: https://www.digikey.com/en/products/detail/ametherm/AS32-10015/2614390
