Geometric chasers
OK , you got a good one there ! :encourage::grin: Push or pull stop . You're good to go .
I still need to find out about hook angles....
Okay, I missed it, I should be good with 15 degrees.
Yes , and you know you can re-sharpen those expensive chasers . I just happen to have the fixture here . All you need is a surface grinder to use it . How's your shop space ? :grin: momoney
I missed the thread size you posted . 7/16-20 for the arm . I'll check but it would be easy to make now that you have the head . :grin:
No room,at the inn.
@mmcmdl Does it look like this?
Mine is home made . Just a little grinding fixture I made up way back when . The above may be an original but not sure .
