- Oct 4, 2016
- 7,021
I am using a spline wrench, and open end wrench to tighten the R8 arbor for what ever tooling I'm using. When it's time to change tooling I loosen the jam nut back it off, and use a dead blow hammer to drop the arbor. Is this correct, I'm not putting a ton of torque to tighten it. I see some of the power draw bars use up to 135 LB FT how would you get the arbor to drop?
