- Dec 18, 2019
- 6,463
Trying to adjust the backlash on the compound rest on my G0752Z. From the instructions, it says to loosen the set screw 231 and turn the threaded collar 230. Did that, but can't seem to do better than 0.009" backlash. Grizzly says to not try to do better than 0.003", but I am far from that! The handle gets harder to turn but the backlash doesn't improve. I used a dial indicator to check when the compound actually moved. Is this the right way to measure it?
Also, the compound graduated dial seems loose, so loose it nearly spins freely. The dial on the compound is a lot looser than the one on the cross slide. Is there an adjustment for the compound dial looseness? Any suggestions on how to get it less free wheeling?
