- Aug 6, 2015
- 3,892
Fixed and mounted!
I have the blues! . I will remove them and do that. Thank you!
That's actually good. Means you have a lot of adjustment left in the gib. Screwing it down increases the tightness. On my G0704, it hangs out at least that much below the slide and isn't tight enough. Need to scrape in a new gib.
I highly recommend purchasing some Hi-Spot blue and checking the gib/slide fitup. It is probably worse than you think. Some of that can be corrected with gentle bending (if the gib is bowed) or locally scraping/lapping off high spots.
