- Aug 6, 2015
- 4,133
Something is different from the configuration I had in the old computer... all three axis are accelerating at a faster rate than before. This is creating a torque that makes the leadscrew slipping on the coupling... I need to fix the acceleration on the motors. Seems like they go full blast in a split second. The movement is still control by the Pendant wheel/control... that is not the issue...
I need to go over all the configuration again...
Also I had different motor profiles/config...
This is what it looks like in the new machine...
I tried playing with it to slow it down...
Doing some searches I came across this document: https://www.machsupport.com/forum/index.php?action=dlattach;topic=27363.0;attach=38008
I might need to look at the Kernel Speed setting on the old machine... that might be influencing what I am seeing...
I need to re-trace my steps when I did the configuration... something is not correctly setup... I also need to go over the manual section on Motor Tuning...
Once this is resolved, is it worthwhile to take apart the motors and apply some loctite on the coupling and motor shaft?
