- Jun 20, 2016
- 346
My bearings are not shot in the quill head ... it's a new machine . If my spindle were chattering around, i'd lose the mirror finish at 650 Rpm . It still gives a mirror finish at both 370 & 650 but as I've said, I don't like the shimmy it produces at 650 so I've ran it at 370 Rpm . Suburban clearly states that this is an un balanced toolI would call Don and discuss with him, he will probable tell you your bearings are shot in the quill head.
From the Suburban website "
The FCS style fly cutter is NOT a balanced cutter. The safe rpm limit for each machine will vary
based on the size and rigidity of the machine. Never start your spindle at over 650 rpm. Serious
vibrations can occur at higher rpm, which could damage the machine and / or cause injury to
the operator. If higher rpms are required, start off under 650 rpm and gradually increase the
speed, noting machine vibration. NEVER exceed 1200 rpm on any machine that is not FULLY
GUARDED."
