- Mar 26, 2018
- 8,411
I probably don't need one, but I would love to make one just for the learning opportunity.My question is do you really need it? I switched to the Jo Pi method last year and it works perfectly. You drill the hole 2 sizes or so under size. Use a boring bar on a light cut to correct any irregularities or mis-alignment, then use the reamer. The reamer follows the existing hole, just enlarging it. I have made several motor arbor extensions in the last couple of weeks and to the best of my abilities, they all are within a tenth of perfect. That is checking on the lathe and on the motor. I have not added any run out anywhere. I looked at the floating reamer here on the forum last year and almost made it. I started checking my work and couldn't see where I would get any improvement. That is just me.
PM1228 lathe, 5/8 PM keyless chuck, PM AXA setup with steel boring bars.
I need a project right now.
