so when it sez 0.375 is that the dia of the piece needs to be thats being cut?Here are two charts....Take a look at 3/8 16 for examples...
Coarse Thread UNC Series
www.efunda.comThread Pitch Chart - Portland Bolt
Standard thread pitch explanations and a chart showing number of threads per inch for National Coarse, National Fine and 8 Pitch threads.www.portlandbolt.com
if the male part was to small then how come it was so hard to thread?? and is that what caused the flat threads??? the thread is 1/2-13The OD of the male part was definitely turned too small. What size thread is it and what size did you turn the stock?
If you're making a 1/2-16 (?) thread, the stock should be 1/2" diameter (a few thousandths under).if the male part was to small then how come it was so hard to thread?? and is that what caused the flat threads??? the thread is 1/2 16
dont rememeber.................will ask this>>>>>>>>> when turning a 1/2 piece down to 3/8 for threading should the major dia be 0.375??This like pulling teeth. What size did you turn the stock?
If you're making a 3/8-(any pitch) thread, then yes the major diameter will be .375.dont rememeber.................will ask this>>>>>>>>> when turning a 1/2 piece down to 3/8 for threading should the major dia be 0.375??
if I used the 1/2 stock w/o turning it down the die would in no way start to even fit..........even if I chamferd the end/Did you actually get a 1/2"-16 die in your set? A 1/2"-16 is an "Imperial Unified National" standard that is not used all that much any more. Your picture shows that you turned down your stock too much. If it is 0.500" stock, you shouldn't have turned it down at all, except maybe a skim cut to remove the outer surface.
so what your saying is I made the work piece to small right, thats why I got the flat threads right???Did you check the major diameter of the material, smaller than required will not form the peaks..
