- Jul 14, 2017
- 2,448
Today i took apart all 5 cylinder heads. All parts are organised i had couple of surprises. There is lots of corrosion in two of the heads, one has broken camshaft cap, almost all seem to had some work done on them. Many have evidence of replacement valves and cam caps, this engines when they brake the timing belt from not changing the belt on its intervals they bent valve or two but also brake the camshaft and the camshaft caps. The most surprising was the XUD7 head i took of the french engine it has green dual spring on the valves and there is not valve seals, the valve guide is not even machined to aspect valve seat. In so many XUD engines i've work on i've never seen that, i'm not sure why are there dual valve spring or why it doesn't have valve seals, there is no evidence of it burning oil also.
