I’ve found the hardware from the store is a bit looser than the specs call for. I made a table locking bolt for my mill and used a nut to test, it didn’t fit and needed to chase it with a die.
I did not resolve it. I turned it down to 10 mm. My afternoon blew up yesterday with family stuff, and by the time I was able to regroup the hardware store was closed and I just started over with M10-1.25.
I had chosen M14-2.0 without owning such a nut. Also, the first attempt was awful. I was dialing in .010” on the compound most of the time, and we wonder why it tore. Sometimes you just need a fresh start.
Try angling your cutter like I mentioned and see what happens. The other option is to grind a decent threading tool and give that a try. If you do this, use 15 degree relief angles and I bet you won't have any torn threads due to helix angle issues.
