- Nov 14, 2016
- 3,007
I started with a lathe, and use my lathe more often, as my projects have tended to lean towards round things.
I did do some milling with my lathe, as well as rely more on saws, files and drill press and Dremel when I didn't have a mill. Having a mill is nice, and now that I have lots of milling accessories (rotary table, spindexer, collet blocks etc), I could probably get along ok with just a mill if I had to.
However I agree with the post earlier. It doesn't really matter on the anecdotal experience of "used more" from those of us with both, because we tend to use the machine we feel is better suited or at least that we are more comfortable with for the job. That doesn't mean we would not be able to do the same work, if we only had one of the machines.
Before I had either machine I turned some simple parts by chucking the stock in the chuck of a hand drill held in a vise. The parts were shaped with files, sanding sticks and emery cloth.
It worked, but a real lathe makes things a lot easier.
