- Mar 5, 2023
- 65
Sort of. That would probably work, but if you notice, it has "H4" in the description which means it's slightly oversized....the higher the number the more oversized they are and each number overlaps in tolerance. The tapping world can be a rabbit hole with many subtle differences.
I've been buying US made taps off eBay from a seller here in Michigan with good luck. I just bought a 2-pack of 3/8-24 and they're nicely made....H2 so only a tiny bit oversized.
Morse 3/8-24 STI Bottoming Tap HSS H2 4 Flute Taps 2 Pack 34077 | eBay
MORSE CUTTING TOOLS. H2 - 4 FLUTE - HIGH SPEED STEEL.www.ebay.com
Purchased the 3/8" 24 H2 and the tap completely fu*&^%$ my scribe cap. This tap measures .469" vs. the .369" tap I used on this part originally. The threading is nowhere near the same.
Wow. I'm speechless. And I'm remaking my cap tomorrow I guess.
