- Dec 8, 2013
- 2,651
I finally got what I wanted a file hard dye able part. I found the problem is the dye, I got some Rit dry that did what I wanted a nice Gold color. By using battery acid at 16 quarts of water( I used tap water they say use distilled) to 1 quart of acid, a lead cathode, at 5 amps 19-20 volts for 120 mins. the part is a tube 1 1/2" OD x 9" long which comes out to about 85 sq inches of surface (it's anodizing both the inside and the outside). The dye has no salt I've shown a photo of the box you add salt or vinegar for cloth, I mixed it 2 quarts distilled water to 1 packet of dye I might be able to add more water but it did work this time. You can see if you look at the fifth line it said add salt or vinegar to the dye and the bare spot on the part is where I filed though the anodize.
Todd
- :victory:
How do you apply the dye? Do you put it in while you are anodizing? Dip the part in the dye-water mixture afterward?
