I think what your lawyer is talking about is if you write off your shop space on your taxes, then it has to be 100% used for business. If he was saying your workspace from a liability perspective needs to be 100% separate, then that is new to me. I chose not to write off my home office for my business since it is a guest room and not worth the effort to segregate. Another important aspect of an LLC, keep your business finances completely separate from your personal, otherwise a good lawyer will be able to pierce the liability protection and the LLC becomes useless. It also helps you keep all your expenses in one place so filing taxes each year is easier.Yes I actually went to a local lawyer in town and verified that I was indeed allowed to do gunsmithing at my current residence however I wanted to form an LLC and that means I can have no mix of personal life where the business is to be conducted. Meaning I can’t have any items I use for my own personal use such as a washer or dryer for example in the area business will be conducted. Business and personal have to be split. I could have done a sole proprietor but I don’t want that I want an LLC. No mater either way cause I am not allowed too. Cost for lawyer here is 6,000.00 to do the paperwork.
$6,000 to file an LLC is insanely high. It is simple enough to do it yourself, but if you wanted someone to do it for you, find an accountant, should only cost a couple hundred plus whatever the state filing fees are. I did two LLCs here in CT, I think it took more time to find the right paperwork then it did to actually fill them out.
