Thansk guys.
My edge finder won't reach the middle
I can use a piece of drill rod and a feeler gauge, hadn't considered that.
Nervous about shaving an oval in it. I might screw that up.
The indicator plan sounds interesting.
The ring is about 6" OD, so I can't really get a straight edge up against both sides very well. It's exactly as wide as my vice so the vice mount gets in the way.
I could put a bigger square on 123 blocks or something, but I don't have enough room on both sides of my vise (without remounting vise), and my squares are limited, too.
if you use a mill that is smaller than the hole, the flat will be completely gone. Another potential advantage of this method is that you get a nice flat surface for the drill to start.
This is how I just did a arbor for my shop press.Since you have a DRO, you could find center front to back with your edge finder. Then move off to one side on center. Lower the spindle down as far as you can. Come back and find the "edge" of the part at that height (even though the point of contact is somewhere along the arc of the part). Then go to the opposite side of the part, again at the center front to back, with the spindle/edge finder at the exact same height, and find the opposite "edge" at that height. Split the difference between the "edges" found. You will be pretty darn close! You could try the same process described above again at another height just to check yourself! A circle is a circle! One half is a mirror of the other.
