- May 16, 2016
- 1,697
Bobshobby, thanks for joining in and for your comment, throughout this long thread we have covered a few of the misconceptions you are talking about already,i.e. 3 point cutter vs 2 point or one, 3 point EMs being the least suitable for a mini mill due to their lack of power and rigidity ,my original post was what I had gathered by reading other threads relating to indexable end mills and their appropriate sizes for smaller /less powerful milling machines but the more seasoned members did put me on the right track but thank you again to reiterate the points for clarity.we are here to learn and I for one appreciate all the help I could get .
Ken, back to your original question, you mentioned the max. dia. of a milling cutter on your small mill. If you use a single point cutter, aka a fly cutter, the only limit to dia is how big a cutter can you swing without hitting anything. The other factors you will need to consider if you have a variable speed motor rather than a gearbox do you lose much torque at low speeds, if so that could also limit the size. Also make an effort to balance the cutter so that the spinning out of balance does not cause wobble problems. make a large dia cutter head so as to act as a flywheel this will help with balance but also help with torque when cutting at low speeds. With a large dia cutter head you can drill a radial hole diametrically opposite to the cutter, and fit a bar without cutter to be used as a balance weight.
