I think I see now. The gear blank is angled with respect to the hob which cancels out the pitch of the hob.
If you wanted to make a gear to be driven by a worm you would just keep the blank at 90 deg and the pitch of the hob would have to match the pitch of the intended worm.
If you know anything about gear manufacturing, you’re probably somewhat familiar with hobbing. But if you’re new to the game, it may sound like a strange term. Hobbing is an important machining process that allows manufacturers like Federal Gear to cut precision gears from raw materials. It’s...
fg-machine.com
Ah, that makes sense!
As designed, I don't think this could do worms, I'd have to do that on my lathe
BUT, it should be able to make enough gears for itself, and kill my time as a shop project, so it'll accomplish my goals at least
Fortunately, there is a local group for model machinists (I haven't got out to a meeting yet!), where both the designer and plans maker are members, so hopefully I'll have resources to get the answers I need.
I STILL have no idea how the lead-screws work for any of the three axes (though 2 are the same!), but that is a problem for 'later Erich'.
The nice part is I'm getting close on castings. Once I get the angle plate, I'll have what I consider the 'main tower' done (though lead-screw brackets I'm holding off until I have the lead screws made, as well as the feed-gear quadrant which I'm holding off until the lead-screw bracket is done!).
I still need a replacement hobb-spindle housing casting, which after I do THAT, i can do the quadrant for it, and that would be all the castings.
ONE BIG QUESTION I haven't answered for myself: The plans are designed around an NMTB-20 for the hobb and work spindle centers. I don't seem to be able to find one of these AT ALL, they are basically unobtainable from what it looks like. They DO have drive-dogs, which are nice.
I DID find an old forum post at one point, where the author of the plans mentions that the 'original' (this is a modified version of the one
@vtcnc is working on!) was based around MT2. This ends up making a couple of parts a little simpler, lets me use a reamer to get the taper, AND makes for cheap MT2 'blanks' as my tool/hobb holders, which is very tempting. So I'm leaning THAT way.
A SECOND (smaller) QUESTION: Is how to figure out which gear sizes I need, and where to put them to make stuff work.
AND A THIRD, smaller/later QUESTION: What sort of motor I see myself using for this. I went to the electronics-scrap store yesterday to see what they had, and there wasn't anything great (though I DID impulse buy an O-scope, so....). I THINK a treadmill motor is going to be too big, and I don't have a good idea of what size motor to use...
Basically, I'm leaving all of those questions for "later Erich" at the moment, but I figured folks here might have a useful opinion on each!
