- Aug 13, 2020
- 1,342
Add grit to it. Your life depends on it.There are pros and cons. the stuff I have used is very durable It would not put up with a acetylene torch directly applied, but pretty tough easy to clean up spills [oil and such] the big minus is it can be very slippery. Some add "flakes" to add traction . if it were me I would ask about that. So in a weld/burn shop ,, not so good. In a general work area,, not a bad idea. Just my two cents. Good luck on your new home
I thought I would get away with not using the grit in my shop. Then I got rain through the garage door. I felt like I was returning to the 70's as I went down to a split.
I added a second coat with some grit I got off the end of the driveway. Does not take much at all.
