- Dec 21, 2013
- 186
My rule of thumb for tightening a drawbar is finger tight, followed by between a half- and two-thirds of a turn with the vise or drawbar wrench, while holding the brake of course. Usually I just do about a half turn. Over-tightening, of course, can break drawbars or strip threads.
But as to the OP - a set of collets will do you just fine. If you were to get a roughing end mill - then I would consider a solid holder. But even then, I wouldn't worry too much about it.
For types of end mills - square or flat end mills are for standard work. They are what you need most of. Ball-nose end mills create a whole radius - a 1/2" ball end mill will make a 1/4" radius or half of a 1/2" diameter. Not really too useful unless you need radii, or in 3D contour milling on a CNC... neither here nor there.
But a bull nose end mill, or a corner radius/chamfer end mill, can be useful. These are flat end mills with a small radius or chamfer on the edge. This results in a stronger edge, allowing higher feed rates without chipping. Then again, on a smaller machine, it can also induce chatter.
If I was you starting out, I would buy one of the common sets of 2 and 4 flute end mills you see on Enco all the time - they go from 3/16 to 3/4 diameter. Buy a set of collets that accompany that set of end mills - the shanks are 3/8, 1/2, 5/8, and 3/4. That'd be somewhere around $120. That would get you started in terms of milling cutting tools and holders.
