    Dismiss Notice
Electrical Cad Software Open Source Or Free
Discussion in 'DRAWING, LAYOUT & CAD' started by Keith Foor, Sep 19, 2016.
  1. Keith Foor
    Keith Foor Active Member Active Member
    196
    43
    City:
    Johnstown
    State:
    Ohio
    -Return to Top-
    OK, I realize that this is a machinist forum. However, I am needing for doing presentation and assistance on here specifically with Rotary Phase Converters an industrial electricity CAD software. Honestly if doesn't need a lot. If it has contactors, 3 phase motors, capacitors switches and basic square modules for dropping in as timers that would be all I really need. Any ideas would be great. I actually contacted AutoDesk about it to see if I qualified for the educational software because I was more or less instructing (sharing information) and it wasn't for profit. They said no. So I am on the hunt. If anyone knows of anything, or an add on for a free full featured software like sketchup that would be fine as well.
    Thanks
  2. CluelessNewB
    CluelessNewB Active Resistor H-M Supporter-Premium
    355
    83
    United States Southern Maine
    City:
    Gorham
    State:
    Maine
    -Return to Top-
    I don't know if I would call it CAD software but for doing simple diagrams the open source program "Dia" works ok.
    http://dia-installer.de/
  3. RJSakowski
    RJSakowski H-M Supporter - Premium Content H-M Supporter-Premium
    2,282
    113
    City:
    Barneveld
    State:
    Wisconsin
    -Return to Top-
    I use freeware called Eagle from https://cadsoft.io/ for my electrical/electronic schematics. While it is intended primarily for printed circuit board layout, it can be used to create general purpose electrical schematics.
    It will not be useful out of the box for industrial electrical/electronics work but, as I remember, there is a capability of creating custom components. It has some advanced features for editing connections which should prove useful.
    Keith Foor likes this.
  4. Keith Foor
    196
    43
    City:
    Johnstown
    State:
    Ohio
    -Return to Top-
    I will check them both out.
  5. jagwinn
    jagwinn United States Steel Registered Member
    4
    3
    City:
    Gaston
    State:
    South Carolina
    -Return to Top-
    USMCDOC likes this.
  6. maker of things
    maker of things United States Hermit H-M Supporter-Premium
    159
    43
    Michigan
    City:
    Zeeland
    State:
    Michigan
    -Return to Top-
    ch2co likes this.
  7. Keith Foor
    196
    43
    City:
    Johnstown
    State:
    Ohio
    -Return to Top-
    TinyCAD is what I was after. I am working on drawings now and believe it will go a long way in assisting others when there are discussions of RPC's
    Thanks
  8. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    1,887
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    Do any of these cad programs have a symbol directory set up with all of the common components needed to do electrical diagrams? Are any of them in dwg format to make it easy to use in AutoCAD or Draftsight? Anyone willin to share them with me? Ken
  9. Technical Ted
    Technical Ted United States Active Member Active Member
    61
    18
    City:
    Dansville
    State:
    New York
    -Return to Top-
    4gsr likes this.
  10. RJSakowski
    2,282
    113
    City:
    Barneveld
    State:
    Wisconsin
    -Return to Top-
    Eagle pcb layout software that I mentioned in post #3 above, formerly from Cadsoft, was apparently acquired by Autodesk and is part of their suite of software. There is still a free version. One of the interesting developments is the ability to export a circuit board to Fusion for subsequent fabrication by milling. Should you choose not to use Fusion, the native Eagle file format can be converted to a Step file or other formats for importation into your choice of CAD and/or CAM software.
  11. mmprestine
    mmprestine United States Active Member Active Member
    17
    8
    City:
    green bay
    State:
    Wisconsin
    -Return to Top-
    If you are making PCBs then kicad or eagle. Otherwise autocad is standard for industrial drafting of electrical systems. As recommended draftsight is a free package that will support the industry as it can use the standard accepted *.dwg extension.
  12. markba633csi
    markba633csi United States Active Member Active Member
    269
    63
    City:
    Mountain View
    State:
    California
    -Return to Top-
    I just used gEDA in Linux, pretty nice. Very intuitive and easy saving of drawings to JPEG. Not all schematic editors will do this, or it's a PITA. Also easy to add text to your schematic (absolute PITA with GIMP 2.8, but it's not really a schematic editor) Versions for Linux and Mac OSX , I think Windows too. All basic symbols are there. Then you can use their PCB layout app to design a circuit board.
    MS
  13. 4gsr
    1,887
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    Downloaded them. So far they look nice and easy to drop in as blocks in a drawing file. Explode the blocks modify them and save as new blocks as needed.
    I had to move them over to my "Blocks" directory for easy retrieval. Not real sure why they have you to download them to the directory they specify. Not the way I use them. Oh well!
    Ken
  14. ammomfg
    ammomfg United States Iron Registered Member
    0
    1
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    So while it looks like this post has been floating around for a while, I thought I would chime in...
    I've used a lot of PCB-design software over the last two years, I've largely settled on KICAD, it has a reasonable work-flow, and kinda the big advantage to it is that the symbols are not connected to the actual part. This is a good thing as it allows you to choose a diode in the schematic, but then it can be any of the dozen or more actual physical packages that need a board footprint. There's also a lot of how-to videos on youtube that help you get your feet wet. "Getting to blinky" is kinda the essential set of videos that helped me greatly.
Share This Page
