- Mar 26, 2018
- 8,409
I have a hard time using the double ended ones.I use an edge finder similar to the ones below almost exclusively for finding edges or centers of my part.s. I do so because, with care you can locate an edge to within +/- .0001" and because the edge finder locates and edge relative of the spindle axis, regardless of any runout you may have. I use the 1/2" diameter one most as it seems to be more sensitive.
Used properly, you approach the edge slowly and as you do you will see any wobble in the tip reduced until it is spinning true to the spindle. As you move a bit further, the tip will jump to the side. This is the point of first contact with the edge. If you note your position on the dial or the DRO, you can lift the edge finder and continue moving 1/2 the diameter of the tip and your spindle will be exactly over the edge of the work.
If you are working from the dials, you will need to know what your backlash is to determine what the dial reading will be if moving in the opposite direction (away from the edge). Backlash can be determined by locating the opposite edges of a block or hole of known size. The difference between the measured and actual size will be the backlash. Keep in mind that backlash can vary with position, especially on a worn machine.
A DRO simplifies the process since backlash isn't of concern. The position is determined by the DRO reading. Even on a worn machine, it is possible to determine position to better than a thousandth.
In an ER40 collet, they get stuck.
I use edge finders all the time, single .200" spindle.
