- Feb 24, 2018
- 1,044
Apparently something has changed, I’m no long allow to shop as a guest, I now must have an EBay account, to buy anything. I have an account, but for some reason, it will not accept the password. I then go through the process to reset the password, I’m allowed to shop, but the next time, I try to buy anything the whole process, has to be repeated. I spent close to 4-5 hrs, over a 3 day span, numerous phone calls, to no avail and the issue still remains. According to them, I just can not create an additional or new account, to shop, I need to use the original/broken one.
this apparently is my clue to avoid EBay at all cost
all this started with my desire to buy a milling machine drawbar wrench/hammer, I have 3 of them, but apparently, they are all buried under/behind about 3/4 of a ton of steel plate and rolled rings, that not inclined to move at this point. Over the next 2-3 weeks, they will be turned into 3 burner adapters, numerous brackets and supports and 2 stack dampers.
