E-Clip Grooving Tool
bretthl
Oct 16, 2017
339
Grooving? Anyway ... anyone know of lathe tooling specifically for cutting E-Clip grooves? I currently use a tool made from O1 but it is not great, I have to cut at 30 rpm.
For some of the larger ones I use my standard parting tool, which is 0.040 wide and for narrower ones I have ground down a HSS tool blank similar to a parting tool.
David
David
I need a 0.050" wide groove.
My mistake. Yes, that is an internal grooving tool. For external grooving, a simple HSS parting tool works fine. A P1-N blade is 0.040" wide and should work well.
The clip is 0.042". Do you know of a wider cutoff insert? That would be ideal. I have only an HSS cut off.
Ditto; grind one from a tool bit.
This is what I have been using but it is slow (O1 Q&T 0.050" thick). Stays sharp. Does not cut well. Have to turn it at 30 rpm with oil. Is the shape wrong?
I have 60 of these to make (+ additional machining) and I have made only 20 shown below. T416 1/2" round.
