- Sep 28, 2013
- 4,308
I really cheaped out and bought one of the HF 29pc TiN fractional sets, as I couldn't (can't) afford one of the full 115pc sets. It's okay - a few of the drills aren't straight, so cut oversize by a bit, others had uneven grinds and some have broken, which I've replaced by 135deg split point cobalt drills. Those are world above the 118deg point drills in the cheap set - start more easily and without a pilot hole, don't wander and cut straighter. I've reground a couple of the HF bits and as I use them now I'm taking the burrs off and honing each one on my arkansas stones, which seems to make a big difference.
For $10 I really can't complain and given the financial circumstances, I'd do the same again. I'm just looking forward to the time when I can afford a decent 135deg split point set
As for getting the right drill for a tap, there's usually enough wiggle room with thread depth that I just hold the drill in front of the tap and see which one works the best. For the stuff I do (mostly alu), I can get away with that.
