- Feb 27, 2014
- 2,131
I don't know for sure, but my guess is that is has a small spool valve that basically compares the current pressure with the max pressure that it has seen (recently?) and when the delta is large enough it cycles. It does not seem to cycle every time I run below the low pressure set point and when it cycles it is about 3-5 seconds. I don't have a way to tell how often it cycles. I only notice it when I am near the compressor when it does. but I crack the manual valve every now and then, and no water is coming out, so It must be keeping up. BTW, there is no adjustment to it.@Boswell, I guess i do not understand how your mechanical valve works??
first, if I had found an electrical one that could be set to cycle like one every few days or a week, I would have gone for that, but the ones that I looked at had a maximum cycle time that was pretty short, like 99 minutes or something. I leave my tank pressurized all the time and I don't want unnecessary cycling when not in use. I was about to get an electrical timer version and wire it after the compressor switch so it was only powered when the compressor was running when I found this one. If this one quits working then that is probably what I will do.To open and let the water out it is also letting air out, how is that less wasteful.
I have made a bunch of improvements in my air system but it still is not as tight as I would like it. At one point it would cycle about once every 6 days. (when no air was used) When I replaced the tank and rebuilt the compressor it now cycles about once every 2.5 days. so still work to do.
