  • Untitled 1
    As promised, a formal announcement has been made regarding recent changes in the administrative staff here at H-M.
    Please take a few moments to go to our home page and review that announcement.
[4]
Does anyone know where to buy 1"by 9" dowel pins
[10] Like what you see?
Ebel440
Active Member
May 24, 2014
549
Likes
82
#1
Hi Ive got a fixture that needs to be modified and the original used 1" dia dowel pins 5" long to locate on. The fixture needs another four inches added to the capacity which means I need 9" pins. I've checked Msc and McMaster and didnt see them checked ebay too. I could use ground stock but it would be much easier to just get the pins already done. Do they even make them this size? I could use longer ones if that's all I could get. Thanks
RandyM
H-M Supporter - Premium Member
Staff member
H-M Supporter-Premium Member
Apr 12, 2011
1,900
Likes
1,522
#2
The longest I could find is 6 inches. I think you'll be making them. You could try calling Fastenal.
Dave Paine
Active Member
Active Member
May 10, 2014
434
Likes
293
#5
The 10 in pin is expensive. I think if he has to cut, it would be cheaper to purchase a 36in piece of 1in O1 drill rod and cut to length.
Ebel440
Active Member
May 24, 2014
549
Likes
82
#6
Thanks. I lied a little bit I didn't look my boss did or told me he did. But he does not use the Internet so I'm sure he just checked the paper catalog. I checked Msc myself. The pins need to be hardened so drill rod wouldn't work. I already ordered a hardened and ground rod that's 18" but looks like I'll get the pins instead. They are actually a lot cheaper then buying the rod and cutting them.
Dave Paine
Active Member
Active Member
May 10, 2014
434
Likes
293
#7
I read you will be buying the pins. FYI, drill rod can be hardened. It is normally sold in annealed state for ease of machining. I have hardened small pieces with a MAPP torch. Larger pieces would need oxy-acetylene to provide the heat. If you can get the piece above critical temperature, then it will harden when quenched. Next step is to temper.
Ebel440
Active Member
May 24, 2014
549
Likes
82
#8
I know the drill rod could be hardened but its a close sliding fit I'm sure any attempt by myself to harden it would most likely result in size change, oxidation or warping. So in this case it is better to buy it already finished. But now I have a nice 18" rod to check the alignment on my lathe with as I have the pins ordered and had already bought the rod to make them
Eddyde
Oct 13, 2014
915
Likes
601
#12
I believed him when he said he had checked with them.
So did I, It's just that it can sometimes be hard to find things on the McMaster site. So I figured I would help him out, I did not mean any disrespect to him or to you, by double checking and suggesting a possible solution.
RandyM
Staff member
Apr 12, 2011
1,900
Likes
1,522
#14
No harm, no foul Eddy. We are all good here. Looks like we have given him some options to think about.
[6]
[5] [7]
