There's a love hate relationship with HF. You can get some attractively priced merchandise there in more than a few "departments". There's also a lot of stuff that is just plain junk. If you have a discerning eye, then you can pick up a few items.
I have done well on occasion and also been burned. Wrenches and sockets were decently priced. However, HF is not a good place to buy a single socket anymore. If you need to turn a socket into a hex insert, or one of your 10mm sockets has gone into hiding, forget it. I found this out recently, trying to buy a single socket for a 1" bolt. They're phasing out having individual sockets.
I have bought several tool cabinets, (rolling tool carts with lots of sliding drawers) from HF and they are great. They're a good value.
Did get burned on their pipe theading kit. The NPT dies were wrong. I cut and hand threaded over 50 feet of 1/2" iron pipe for garage air distribution. I hung it up by the ceiling. Every pipe joint leaked terribly. Comparing the threads to a normal pipe thread showed the problem, the taper wasn't correct. No amount of pipe dope would stop the leaks. Still haven't fixed this - really took the wind out of my sails. Guess I will fix it this summer. In the meantime, I inherited some Ridgid pipe dies, even being 70 years old, still cut beautiful NPT threads, with the proper profile. The Ridgid threads require a tiny amount of dope or tape to seal. So the kit I bought from HF was worse than useless, since the dies were counterfeit. (Sold as NPT, but being nothing of the sort.) Will cost me a lot of time, and sweat to replace the piping, moving things to gain access, removing each piece from the ceiling, cutting the threaded ends, rethread, rehang and hope that I can adjust things enough since each pipe is 1.25" shorter than it was before.
Others may have similar stories. Some good, some bad.
