Do I need a swivel base for a mill vise?
my swivel base is still coated with the preservative that it came in there are many other ways to cut an angle. so I have one but have not used it. yes I am a toolaholic. that can not spell. when you need one you can get one bill
You did not mention if a manual mill or NC, if NC a swivel base would be redundant much like having a compound slide on an NC lathe.
Or just use a fixed vice and clamp it to the table at the desired angle, if the angle is critical to the function of the part you will have to indicate either vice because you can't just use the angle marks on a swivel vice base.
