- Jan 4, 2021
- 2,851
great suggestion woodchucker on radius end mills. that would minimize the chipped corners, i should try a few with at least a .010" cr. On the tips though that i have broken, they've been on drill/mills. i generally don't use them except in circumstances where i have to drill a hole on a radius surface. hate it when that happens.
definitely agree with having rigidity too jwmay
If you need to drill a hole on a curved surface, just spit face the surface then finish with a drill. If you need a square bottom you can clean up the bottom with an end mill after drilling. See this post:
