In that case, I wouldn't even bother with welding the nuts. Go with just thru bolting the feet on. One nut on top of the mill base and one between the foot and the tube.
The feet have to be spaced widely enough to get the pallet jack between them.
You may find that those style levelers give you big stability problems. Using a leveler with even high durometer inserts will allow your mill to move around a bit. Depending on how much it moves, it may or may not be acceptable to you. I know at work the only machinery we put on on isolaters, were compressors, drop hammers and forging presses.
If your worried about the front of the mill tipping forward, weld you a couple and angle brackets that will go to the floor. Then run a couple of lag screws into the concrete on the back sides of the mill.
Can't help you there. What ever you do, keep it as close to the floor as you can while moving the mill if you are using the pallet jack. If you want to move it on some kind of rollers, Find you some cam roller bearings and mount in a pocket cut in the square tubing. I have a couple dad made for moving machiney around the shop with.I'm only worried about the tipping when it's being moved.
