Any reason why I shouldn't weld these grade 5 nuts that I turned?
The plan is to weld these nuts to the inside of some 2in x 3in x 1/4in wall steel tube.
The steel tube will run laterally underneath my Series1 Bridgeport
The "base bolts" on the Bridgeport will screw in to these nuts.
I understand the heat from welding may affect the properties of the nuts, but perhaps not significantly for my application.
The Bridgeport is "trying not to go anywhere" just due to simple weight alone.
If these weld nuts are unsuitable, what would be a recommended alternative?
