- Nov 27, 2022
- 108
Good evening everyone. Just bought a Lagun mill. It's clean and in fantastic shape. Before placing it, I opened up the rear access for the coolant and pump. What I found was... disturbing. Maybe it's normal, and that's why I'm floating this to you guy's.
Inside was an inch of sludge, swarf and chips. The consistency of a thick batter. On top of that, was an inch of oil-ish fluid. I should have gotten a before pic. I'm pretty sure that I'm the first one in there since the factory buttoned it up. I removed the pump, oil, sludge, chips and thoroughly cleaned and de-greased.
So, how come no filter of any sort? Not even a sump for the large debris? Chips can flow from the table to the reservoir to the pump and back to the table? I did place some strong magnets where the fluid deposits, but what about non ferrous metal? Or is this just not an issue? Thanks in advance.
M. Noob
M. Noob
