- Jun 7, 2013
- 10,154
I just did a search to find my Geometric die brochure describing all the different types, but of course stuck out, but my advice would be, consider ONLY the style D die head.
All true and good advice. I made a sleeve that fit my 9/16 die head that slipped over the tailstock quill, that had a key to engage the keyway in the quill and a setscrew to keep it from sliding off. I would set the carriage in position to limit tailstock travel for the length of threads wanted; the tailstock would run into the carriage and the die would trip and open up. Later I adopted the Aloris boring tool holder with 1 1/2" hole and mounted the die head in it and used the carriage stop to trip the die. I have tried using the lead screw to power the travel of the die head, but generally, this does not seem to work, as it seems that deviations in the pitch diameter (of the part being threaded) effect the lead of the screw being cut, and generally with a long cut, the die will pull itself off (trip) before the desired length is reached, so the lead of the thread would be longer than expected, this with undersize pitch diameters.This is the size I have. I have chasers from 4-40 up to 1/2-13. I just hold the straight shank in my tailstock Jacobs chuck, that opens to 3/4”. I can change to a different thread pitch in maybe a minute, after I remember afresh how to do it each time.
The thread quality for me is at least as good as single point, and I tell you, zap, it’s done. I would and have set this up to do a single part.
