- Jan 15, 2016
- 9
I recently started a job running a grinder. I grind 10x50 inch rolls that crush wheat and stuff like that, they then get corrugated. The problem is that the grinder I run is old, I mean really old, I don't even think the drive motor welded on to the table is the original one, the journals of the rolls rest on v blocks with leather straps as cushions. The drive pulley that the drive dog is connected to wobbles, a lot, 28 thou out of round, the journals only wobble 2 thou. I was told the machine was inspected and the table ways are worn along with the spindle bearing for the grinder wheel. The v blocks are just open, there is no stabilizing equipment or anything other than a tail stock adjustment. I have no idea what make or model this thing is, it's just old and green. I am expected to hold a 0.0001 tolerance perfectly across the whole roll, the thing is, these guys I work worth that are training me usually only check the ends and middle of their work, now that they're training me they measure every 2-4 inches, which is fine with me, but once we run the roll again just for a clean up or finish and stop it again and it stops in a different spot we get different measurements in certain spots, high and low spots in a wave, in the same spots every time, they keep assuming that I am adjusting the tail stock when they walk away or messing with the wheel while the table is traversing, I'm not of course, the problem is that the roll never becomes completely round with all of the machines issues and the speed they make me traverse at. They then try to show me how it's done and still have problems and then act confused and assume I did something again when they walk away for a moment. There are parts of the roll that are strainght, but, mic the whole od and you discover high and low spots, but they only find those spots by chance when the roll stops perfectly at those spots. Anyways, do the problems I describe such as the worn ways, spindle bearings and wobble in the work head sound like the culprits to my issues? Also, I can hear the wheel missing in the same exact spots every time and it is always right in sync with the wobble of the work head, I put an indicator on it and watched the needle move right along with the miss of the wheel, in the same exact spots every single time. Any input?
