- Dec 21, 2018
- 1,829
About perfection: I don't think two gears have to mesh perfectly to work fine for a long time. As a matter of fact I doubt that perfect mesh is normally obtained on a banjo setup. I've eyeball ground cutters for a flycutting type setup that produce gears that seem to run fine. Using a softer metal for the replacement gear minimizes wear damage on the original that it meshes with. They will "wear-in" to an even better fit.
