That type of blade you have to grind the top of the blade flat for about a 1/2" back, maybe even a little future. Just depends on the OD of the part you are trying to part off..............
I noticed that my HSS cut-off blade has an odd profile on the top edge. Is this normal? Seems to me it might cause it to have more force to one side vs. the other. (See pic.) The top profile angle and depth has been exaggerated a little to make it show up better in the picture. The small cut-off blade I have does not have this type of profile.................
That beveled edge is what bears against the screw or bolt that secures the blade in the holder. It's always been like that until someone came out the "T" shaped blade. Now the T-blade doesn't really fit old style holder properly, not even a Aloris No. 7 holder. But most of us use it that way. To use the T-blade in a conventional holder, a shim needs to be inserted the base of the T-Blade and the side wall of the holder. Doing this will keep the blade square to the work and not worry about the bottom of the blade dragging against the work piece while parting off.dlane. Wow, what a great idea! 4gsr, any idea why they supply the blade that way? Grinding is easy but why?
