- Mar 25, 2013
- 4,615
I modified the fork by adding a tab with a hole. I modified a torque arm so I can lock it to the tab with a screw. This will prevent the axle from spinning in the dropout and also locks the wheel in the fork. Much safer design I think...
In the first pic you can see my 21.2 mm washer. I had to reduce the diameter to nest in the forged impressions in the fork.
A little more sandblasting, some rust converting primer in the fork tube, and then paint! I plan to strip the stupid looking black rings off the motor cover too.
Robert
Robert
