    Dismiss Notice
Craftsman Repulsion Induction Motor Wiring
Discussion in 'ELECTRICAL ISSUES - POWER YOUR MACHINES & SHOP' started by Alittlerusty, Jun 24, 2017.
  1. Alittlerusty
    Alittlerusty Active Member Active Member
    79
    18
    City:
    Plympton
    State:
    Massachusetts
    -Return to Top-
    IMG_1067.JPG IMG_1068.JPG IMG_1069.JPG IMG_1070.JPG Hi I'm trying to wire up a 1 1/2 hp 115/230 volt vintage motor and don't know where the elecatrickery goes .It's a model 551-1940. I'd like to wire it for 115 initially so I can just throw a plug on it and see if it's ok . If it is then I'll wire it 230 to install it on the machine when I get that setup. And some pics.bottom left of first pic is 115volt diagram( flash was on) thx in advance!!
  2. markba633csi
    markba633csi United States Active Member Active Member
    314
    63
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Looks like there are just 4 wires so for 115 you just bring them out as two pairs: black/yellow and green/white and connect a cord. Easy as pi :)
    If the colors are not readable you can use a continuity tester or ohmmeter to locate the two windings' ends. But they have to be "in phase" in other words, black/white and green/yellow won't work- probably just hum.
    Mark S.
  3. Alittlerusty
    79
    18
    City:
    Plympton
    State:
    Massachusetts
    -Return to Top-
    Got it thx spun up just fine
  4. markba633csi
    314
    63
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Good deal, just follow the 230 volt diagram when you get to that point, be sure you have a safety ground wire to the motor frame too.
    Mark S.
  5. Alittlerusty
    79
    18
    City:
    Plympton
    State:
    Massachusetts
    -Return to Top-
    It was wired 230 already but they had used green as a load wire , had me second guessing and didn't want to smoke it
  6. hman
    hman Active User H-M Supporter-Premium
    939
    113
    Tempe. AZ -and- Corvallis, OR
    City:
    Tempe
    State:
    Arizona
    -Return to Top-
    Just for fun, I played with your wiring diagram photo a bit. Looks like you've had your questions answered OK, so by now, this will be redundant.
Share This Page
