- Apr 30, 2015
- 11,304
You really want to be around 220-350 rpm for drilling larger holes in steel. You'll burn and dull drill bits more quickly if too fast.
Mark S.
Mark S.
Mark S.
OK. Then what you need to start looking for are (although they may be made by many different vendors) are Silver and Deming bits (after the name of the company that first made them). By default, they are all the same length as a jobber length 1/2" bit. All have either 1/2" dia. shanks, or that plus three flats ground on the shank so that they will not slip. Some are available from 33/64" to 1-1/2" in 1/64th increments. Less expensive sets have only 1/32" or 1/16" increments. Or if you only need say 3/4", you can buy just that.
What I found in the archive is a model year of 1955. It is younger than I am, but not by much. It runs well and looks to have all of the original parts............If you were to price the 103 by the pound, I think I did okay on the purchase. That doesn’t include the cost of the visit to the chiropractic to relieve the back strain from loading the thing in my truck.
I have also found a reference document for a ‘multi-speed attachment’ that I’m sure you all have knowledge of. The set of pulleys mid-way between the motor and spindle provides wider range of speeds with a lower low and higher high RPM. This drill does not have that, but it may be an option. My initial search found several online, albeit pricey. I’m not in any desperate need, buy I would like your feedback on that option if you have any.
